Re: Janicholson - CUB problems
Posted by Janicholson on July 26, 2010 at 08:23:24 from (199.17.55.140):
In Reply to: Janicholson - CUB problems posted by 47H on July 26, 2010 at 05:33:11:
I will suggest that you first start the tractor, run it at 3/4 throttle, then use a jumper to ground the Field terminal at the gen. This will start it charging. (or not) if it charges only when shorted to ground, it is the VR (either it is not grounded (you said it was super)or it is not good even though new).
If it stays charging after removing the jump to ground, the third brush might need to be moved closer to the fixed brush to charge higher output. Try these things then get back. Jim
