Janicholson - CUB problems
Posted by 47H on July 26, 2010 at 05:33:11 from (67.63.145.97):
About a month ago we had an indepth conversation about the electrical problems I was having with my 1948 Cub. If you will remember EVERYTHING is new: Mag., Mag switch, wiring, 6V VR, gen.,3 position light switch, new battery. Wiring is correct and gen polarized to VR, would not charge. Was told on here to check all grounding areas. There is metal to metal on mounting bracket from water pipe to gen. and metal to metal were gen and VR mount together.Replaced original Ammeter with a new one from OEM (American Made) checked all wiring and re-polarized, started her up and I finally got a charge reading on the Ammeter of about 6 to 7 amps, turned on my lights and she dropped to about 2 amps., this was at about 2/3 throttle. Shut the tractor off and started it back up and guess what, NO CHARGE!!!! Turned the lights on and it showed about an 8 amp discharge. What do you think? Thanks in advance.
