Fan Belt adjust on C
Posted by fredmich on July 26, 2010 at 09:47:18 from (205.188.116.73):
Hey Guys, what's the secret or trick to adjust the fan belt on my C? Has anyone got a way to do this easy? Do you have to grind down a wrench to get on the nut to loosen it because there is hardly any room to get on the nut. Or is there a washer or spacer missing on mine that don't let it stick out enough. I assume the nut on the end is captive and you have to turn the one on the front of the bracket it slides in? Help I need to tighten mine. Thanks....Fred
