So you now had it charging. That's progress but there still is something weird going on with that discharge with lights on. I'm not sure what the answer is since I believe your regulator should be compensating for the additional current draw by the lights so your ammeter should be relecting a slight charge, even with the lights on. There should be no discharge with the lights on if your engine is at half or slightly above half throttle.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
