Re: Front bolster shaft removal
Posted by Dan G on July 26, 2010 at 18:09:48 from (184.8.138.128):
In Reply to: Re: Front bolster shaft removal posted by Seth Boyer on July 26, 2010 at 06:50:46:
Tires are a match. With front end jacked up, when I turn the wheel, the front wheel assy goes side to side several degrees. With the sector gear cover off, you can see that the worm moves quite a bit before engaging the sector. Soooo where to get a worm shaft? Is it something that can be remachined or ...probably not worth it...right? Gonna look aftermarket tonight.
