It will help a lot by just replacing the sector gear, but it will only be that much better if you replace both the gear and the worm gear shaft.
There should be a nut on top of the sector gear. I couldn't tell by your pictures if it had been removed. The splines on the gear and the shaft are tapered so it might take a little work getting it off.
You can also tighten up the steering my checking the worm gear shaft in the housing by the gages. A machine shop can build up the shaft and have bushings installed in the housing if needed. The U-joint shoulnd't have any play. You may have luck finding a new/used rear shaft with a tight joint or that one can be cut off and replaced. Same thing goes on that shaft where it passes through the steering post. You don't want a lot of play there.
Another thing that will affect the wheels wobbling is the tires. You need a matched set and make sure they have equal air pressure.
Some tractors had an aftermarket "wedge" installed between the lower bolster and where it bolted to the pivot shaft. This adjusted the angle of the lower bolster making it more vertical. This change makes the tractor easier to steer but I'm told you do sacrifice in that it may make the front it wobble.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
