Re: Hand Cranking
Posted by SteveF on June 07, 2000 at 18:01:46 from (64.41.17.183):
In Reply to: Hand Cranking posted by gn on June 06, 2000 at 12:52:14:
I don't know how similar your sheet metal is as compaired to my "A" but on mine there is a C shaped bracket right behind the grill that the crank passes through. This bracket does two things it supports the crank and also is the lower attachment point for the grill. If yours is missing the crank will not fit secure.
Good Luck; Steve
Post A Followup
: Re: Re: Hand Cranking
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
