Re: Re: Hand Cranking
Posted by Dave on June 07, 2000 at 18:21:42 from (128.113.170.149):
In Reply to: Re: Hand Cranking posted by SteveF on June 07, 2000 at 18:01:46:
Or if it's worn out. Over years of use mine has worn to the point where it's has a rather large oval hole in it. The two bolts that hold it in place are long enough for you to put a 3/16 inch or even 1/4 inch doubler plate over the front to act as a bearing surface provided you have a way to get a snug fitting wing-nut shaped hole through it. (I used the "file and fit" method.) This is for the A, as Steve mentioned.
Post A Followup
: Re: Re: Re: Hand Cranking
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
