Re: Super C starting issue
Posted by teddy52food on July 27, 2010 at 19:50:39 from (68.169.216.43):
In Reply to: Super C starting issue posted by Farmall Freak on July 27, 2010 at 18:28:26:
If you find it out of time, pull the dist & check the gears. Sounds like they are wore out.
