Super C starting issue
Posted by Farmall Freak on July 27, 2010 at 18:28:26 from (71.80.121.160):
I have a 1951 Farmall Super C with coil ignition. When you crank it over it has good spark out of the coil but nothing going to the cylinders unless the engine rolls over backwards then it has good spark and will run for about 2 seconds backward. I have exhanged the following off of a running tractor cap, rotor, and coil. It has new points and condenser. I also checked to see if power was shorting to the distributor but everything was fine there. Any help would be appreciated.
