One of the field connections (two Brush) is connected to the Brush that is connected to the Arm post. the other is connected to the F terminal. no connection, or short to ground can be allowed. If a three brush the first wire is connected to the third brush. the second to the F terminal. Again, shorts will either cause no charge (if close to the brush connection, or high output, and heat if at the F terminal end. Jim
