Posted by w400 on July 28, 2010 at 22:05:10 from (195.93.21.97):
Hi guys Rain here today came home early decided to strip this generator on my H found to bare wires (insulation detireoated) between fields and posts possible charging problem? has anyone a schematic of the fitting of fields posts and brush wires made a diagram when I took it apart but on studying I think you could put together other way round would like to double check as someone has been in and cleaned out casing and fitted new brushes before my time. Also if any of these wires grounded would this make it over charge (this is inside generator) and somtimes it doesnt charge, and also when charging generator gets quite hot opposed to no warmth at all when not working appreciate very much your input thanks P.S. should I just post it to rebuild shop more £££$$$$ !!!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
