This service bulletin was published in 1953. The IH regulator is similar to the two-unit regulator described in this bulletin. The IH regulator has an additional current limit winding added to the voltage regulator relay. This limits the charge current to the battery, the “L” terminal is not current limited.
Delco-Remy Service Bulletin 1R-116 http://www.ruiter.ca/mc/info/PDFs/1R-116.pdf
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
