1949 Farmall H
Posted by Allan from PA on July 31, 2010 at 05:59:33 from (76.125.180.44):
Got the old girl running after almost 30 years sitting and didn't run too bad, no smoke and plenty of power. Second time it ran it didn't run as good, was missing on one cylinder. Checked all the usual culprits and found nothing wrong. Took off valve cover and the push rod for #2 intake valve was off. Valve was not stuck and clearance seemed OK. Started up again and ran fine. Started up later in the week and it happened again. Is it possible that the valve is worn such that it is sticking in the seat causing the push rod to come out of the rocker arm socket? Seems like a valve job in the future? Thanks, Allan.
