Posted by rustyfarmall on July 31, 2010 at 06:48:33 from (209.152.78.140):
In Reply to: 1949 Farmall H posted by Allan from PA on July 31, 2010 at 05:59:33:
That #2 intake valve is sticking from time to time. Remove the rocker arm, spray some penetrating oil on that valve stem, tap the stem with a hammer several times until the valve moves freely every time you tap it and then put it all back together again and adjust the valve clearance on ALL of them. Use plenty of penetrating oil. You might also want to pull the offending push rod and make sure it isn't bent. Bent pushrods CAN be straightened by laying them down a solid, flat surface and hammering the bend out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
