Re: Cracked block question
Posted by Red Dave on July 31, 2010 at 16:30:13 from (174.59.227.184):
In Reply to: Cracked block question posted by charlie M on July 31, 2010 at 14:48:48:
The most common place for a BN block to crack is the lower water cavity, which is behind the carburetor. There is no pressure in the cooling system, so many, many blocks have been "fixed" by merely sealing up the leak with epoxy or silicone. May not be the best fix, but it is done all the time.
Those blocks also crack the deck of the block between 1&2 cylinders and 3&4 cylinders. That is more serious and can only be discovered by taking off the head and looking at it.
