Re: Steering restoration on an H
Posted by LarryDW on August 01, 2010 at 08:26:09 from (207.224.111.109):
In Reply to: Re: Steering restoration on an H posted by Theman on July 31, 2010 at 11:40:53:
I had tried this method for removing the gear and never did get the darn thing loose. Spent a lot of time pounding on that darned shaft. Gradually went up to bigger and bigger hammers too. Finally lucked out and found a low priced new front end to swap out. Is there some special trick I could have used to get it loose? It's been bugging me why I couldn't get it off!
