Re: Steering restoration on an H
Posted by Theman on July 31, 2010 at 11:40:53 from (166.164.105.237):
In Reply to: Steering restoration on an H posted by David A. Smith on July 31, 2010 at 10:07:25:
It sounds like you're trying to remove the vertical shaft. The large gear is a tapered spline fit on the end of the shaft and that is what is holding the shaft in place. You will not damage the thrust bearing by hammering on the end of the shaft. It is accepted practice to put the nut on the shaft and hit it hard. I use a wood block on the nut as my aim with a 5-pound sledge isn't what it used to be. When the shaft comes loose from the gear, the nut will keep the shaft and bearing assembly from falling on your foot.
mkirsh has explained how to remove the steering shaft which should be done first.
