Stuck 460 diesel engine
Posted by tntleake on August 01, 2010 at 15:09:00 from (70.176.103.253):
I purchased a 460 diesel that has a stuck engine.
I pulled the glow plugs and put PB blaster in there for about a week. I raised one tire and rock it back and forth with no luck. hooked on to it and pulled it on pavement and it just slides tires in 4th gear. I then tried brake fluid and the same results. I have removed the oil pan, which was slightly dented in the sump to find everything looks good below.
Any suggestions on where to go from here.
Oh and when I drained the oil, I found no water!
Thanks for any help
