Re: Several H Questions
Posted by John M on August 02, 2010 at 14:28:32 from (67.231.160.184):
In Reply to: Several H Questions posted by David A. Smith on August 02, 2010 at 12:56:47:
1 - remants of old seal, yes repalce it.
2 - Are you talking about the old black stuff? Is thats the old gasket, and yes replace it.
3 - Ive used both, the finer mesh for sheetmetal, the rougher for the cast parts.
4 - Couldnt tell you, but if you dont fix what caused the problem in the first place, itll happen again.
