Several H Questions
Posted by David A. Smith on August 02, 2010 at 12:56:47 from (72.70.219.141):
third party image
third party image
third party image
third party image
In the photo of the front wheel (back side) ... I see the race ... what's the other (exterior) ring? Do I need to replace it?
In the photo of the front wheel (front side) ... I see the face ... what's the other (exterior) ring? Do I need to replace it?
I've sent a photo of the grinder brushes I'm using to prepare for priming. I'm using mostly the fine brush. Does this look OK?
Finally ... how do you suggest I repair the hole shown above the guage window?
