Re: Several H Questions
Posted by Mad Farmer on August 02, 2010 at 14:30:29 from (137.165.204.216):
In Reply to: Several H Questions posted by David A. Smith on August 02, 2010 at 12:56:47:
For the hole I'd cut a piece of sheet and braze it in, then grind smooth out the surface.
Not sure about your wheel questions.
