Posted by Seth Boyer on August 02, 2010 at 19:48:08 from (72.161.220.212):
In Reply to: Several H Questions posted by David A. Smith on August 02, 2010 at 12:56:47:
You'll be a lot better off just welding the holes in the hood. If you don't feel comfortable take it to someone who's good with a wire welder. It won't take but a minute to fill then you'll be able to grind down and smooth out a bit. The bracket that the gauges are mounted in has become loose and is setting at an angle and wore through...or the "pads" that your gas tank is sitting on have deteriorated or were never thick enough to begin with. Replace these with thicker mounting pads...this will bring up the rear of the hood to the correct height and will keep it from rubbing on the gage mount.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
