As several others have replied it indicates a (male "O" / Female "X", or (plug / socket) connect or disconnect point in the wire harness. The female or socket side of the connector is powered from the HOT side of the battery and the male or plug side of the connector is tied to the GRD side of the connector. The female or socket side of the connector is insulated and reduces the chance of the wiring shorting to ground if the connector is separated and touches any part of the tractor frame. The male or plug side of the connector will not short out beause it is connected to the ground side of the connector. You may eliminate this disconnect point and wire from component to component without any problem other than losing the ability to break the wiring at this connection point.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
