Posted by 7lazy77 on August 03, 2010 at 22:21:41 from (72.36.61.233):
This is in regards to the A that won't crank/start & is completely dead. I played around with it a little tonight & tried your suggestion (using test light between battery cable terminal on the starter switch & ground). The came on & when I pressed the starter rod, there was a little pop at the kill swich on the tractor & the light went OFF. Tried repeating & I couldn't get the light to come back on. So next I took a voltmeter & put the black probe on the negative cable & the red probe on the positive cable. Voltage read 12.14. When I tried to start the engine, the voltage dropped almost all the way down to 0 & sparked once at the negative connection. I am troubleshooting & trying different suggestions, but not quite sure what this tells me or leads me in the right direction to diagnose the problem, so I can fix it & get the tractor up & running & back to work. Thanks for your time & help.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
