Re: attn: Bob and/or Janicholson
Posted by John T on August 04, 2010 at 05:17:39 from (66.244.97.31):
In Reply to: attn: Bob and/or Janicholson posted by 7lazy77 on August 03, 2010 at 22:21:41:
Until Bob and Jim get here, First thing I would do ESPECIALY where you saw that "spark" is to REMOVE, CLEAN AND WIRE BRUSH, AND REATTACH EACH AND EVERY BATTERY AND STARTER AND SWITCH CABLE CONNECTION all clean n bright n shiny. A bad cable or connection may be all the problem is ?????????????????????
AFTER alllllllll connections have been cleaned and re attached when you try and start it see if the lights dim way down badly (i.e. or voltage drops drastically) and if so I suspect a bad starter or perhaps the starter is mechanically stuck/jammed (check that out!!!) However if theres little light dimmage (volts dont drop much) then I suspect more a bad switch or a bad connection
FINALY have a shop load test the battery as the battery itself may be the problem
Hope this helps, let us all know
John T
