Hi, it have only one pump for hydrolic system, include the pto,brake and steering. It have a flow-divider valve that allow 3 gallon to the steering, the steering return goes to the pto,cooler and brake. First check, the oil level, filter, flow-divider, then the pump. The filter is on the left side, in front of the rear axle. Make sure the by-pass valve, in the filter cover, is in the cover and the filter element is toward the housing. The flow-divider is under the filter, remove the large plug, it have a spring and a spool, the spool should be free in the bore, if not,you dont have enough oil flow for all the system. For the pump, remove the housing plate, where the filter is bolted, and the pump is inside. Hope this help. Bernard le mecano Quebec Canada
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
