Re: Farmall light harness issue - please help
Posted by Janicholson on August 05, 2010 at 13:51:52 from (199.17.6.30):
In Reply to: Re: Farmall light harness issue - please help posted by AL Tractor Pickers on August 05, 2010 at 12:21:13:
That looks like the connector for the flasher unit. The diagram is usually on the side of the flasher, Ine wire goes to the hot rrom the lights, one is usually a ground, and the tird goes to the lights. From the lights to ground. if the flasher has only two terminals, the two just go in line with the hot wire from the lights. If this makes little sense, you really need someone to help you on site. Old automotive books are also good. Jim
