Re: F 20-F 30 difference
Posted by 36F30 on August 06, 2010 at 23:00:41 from (71.38.174.57):
In Reply to: F 20-F 30 difference posted by NEKS on August 06, 2010 at 21:00:39:
About a thousand pounds more metal in a 30. The governors and mags are the same, oil filter and base, the seat and seat support are the same, the brake cable pulleys are the same. Other than the sediment bowl and some misc. bolts and fittings everything else on a 30 is about 20% larger and almost nothing interchanges. An F20 drawbar will fit a F30 but they have different hole patterns for the drawbar braces.
