Re: F 20-F 30 difference
Posted by Old-F20 on August 07, 2010 at 07:30:33 from (71.7.98.117):
In Reply to: F 20-F 30 difference posted by 36F30 on August 06, 2010 at 23:00:41:
36F30 said: (quoted from post at 23:00:41 08/06/10) About a thousand pounds more metal in a 30. The governors and mags are the same, oil filter and base, the seat and seat support are the same, the brake cable pulleys are the same. Other than the sediment bowl and some misc. bolts and fittings everything else on a 30 is about 20% larger and almost nothing interchanges. An F20 drawbar will fit a F30 but they have different hole patterns for the drawbar braces.
brake cables are the same??????? WRONG!! better go measure them
an F-30 is longer than an F-20, plus the springs are quite a bit larger on the end of the cable
This post was edited by Old-F20 at 07:32:40 08/07/10.
