Re: Farmall H charging problem
Posted by Russ Moore on August 08, 2010 at 02:26:39 from (67.255.17.217):
In Reply to: Re: Farmall H charging problem posted by pete 23 on August 07, 2010 at 18:10:56:
As far as I can tell the 4 position switch is only being used as a light switch the way it is wired. The ammeter (also new) does show a discharge if I turn the lights on. I am making the assumption either the generator or the voltage regulator, even though new, is not working. I will try shorting the field to ground on the generator. If it charges, I think that would narrow things down to the VR.
thanks
