Don't know about the volume of it but if it is coming from where the pedal is there is a bearing for the input shaft there...I am in the process of replacing one right now for the same reason. Mine just makes a grinding noise. If it is coming from up by the bell housing I would check the throw out bearing as suggested. The first thing I would do is isolate where it is coming from as that will tell you a lot. If you have to look at the pressure plate and make adjustments I am thinking you are talking about a front end split. Time consuming but not difficult. I was lucky...I got to split mine at both ends!
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
