Re: 666 clutch
Posted by pete 23 on August 12, 2010 at 19:10:22 from (173.87.8.216):
In Reply to: 666 clutch posted by Erik Dekeyser on August 12, 2010 at 18:42:03:
What you need to determine is if you have clearance between throw out bearing and clutch fingers. All it takes is like one sixteenth of an inch so fingers do not touch bearing while engine is running. Reason book gives you the dimension they do is so you have some room for wear as free play will as you no doubt know decrease as clutch linings wear. The less you have the more you will have to keep an eye on your free travel and readjust more often. I find these models have very little extra throw on the brg so sometimes you have to cheat a little on the clearance especially as all your linkages wear. I would personally also make sure all fingers are set the same as this can really affect your release problems.
