Re: B-192 Plow
Posted by gene bender on August 14, 2010 at 03:32:22 from (67.55.227.196):
In Reply to: B-192 Plow posted by Haydon Rowe on August 14, 2010 at 02:38:04:
I had one there is a lot of parts to mount and make it work. You need to post a pic of what you have. You should have two levers a rockshaft going between the rear fenders, a wishbone that mounts to the front area and a long heavy soring on a large rod that goes under the tranny then forward to the wishbone thingy.. You can get an owners manual from a dealer they will of course need to order one. You mite even have the model that uses the exhaust lift.Similar model did alsomount on the A.It just had a narrower rockshaft and a different wishbone assy.
