Re: 560D no acceleration, what did I do wrong??????
Posted by casered on August 15, 2010 at 18:27:22 from (71.181.250.92):
In Reply to: Re: 560D no acceleration, what did I do wrong?????? posted by Owen Aaland on August 14, 2010 at 20:11:45:
Owen I ckecked it out this afternoon and everything was together properly, BUT the throttle shaft is slipping on the arm that goes into the pump so I think I got the problem nailed down. Thanks again for the help.
