Re: A couple of B questions
Posted by ScottyHOMEy on August 15, 2010 at 19:18:41 from (71.241.195.50):
In Reply to: A couple of B questions posted by bkpigs on August 15, 2010 at 18:57:07:
My thought is that you're overthinking at this stage. In the 1939-1947 run of the the A/B/BN the motor was a thermosiphon cooling system, with never a thought given to a a temp gauge. Not entirely accurate - there was a gauge and installation available if you really felt you needed one, but such indulgence was not oten exercised. Thermosiphon, ingeniously if not devilishly simple, a fan and radiator size coupled with the older-than-the-Greeks concept of convection for cooling. So efficient that the temp gauge was an option.
Quite simply, if they were clean inside, they didn't overheat, no matter how hard you worked them.
Cool air flowing OUT of the breather??? Balderdash. You may feel a draft there (doubtful -- don't confuse the draft coming back from the engine fan . . . ), but if the motor is actually running, any cool draft at that point is air flowing in, not out.
Trust me, if you are holding your hands over the breather cap, any flow of air that you feel is NOT blowing out of the motor.
