Re: Eliminate the sediment bowl?
Posted by old on August 16, 2010 at 11:05:26 from (4.245.7.25):
In Reply to: Eliminate the sediment bowl? posted by badaugherty on August 16, 2010 at 09:49:54:
I agree with rusty. In line filter in the long run cause many many more problems then they are worth. Plus most are made for systems with fuel pump and made for 5-7psi plus and your gravity flow system will even when full not put out more then 1 or 2 psi if even that much
