Posted by Owen Aaland on August 16, 2010 at 11:43:28 from (207.13.114.118):
In Reply to: 504 utility pto posted by Wardner on August 16, 2010 at 09:25:20:
The adjustment is for the clutch engagement. If the brake is not holding, check to see if there is play between the handle and the shaft that goes into the PTO assembly. The travel of the lever to engage the brake should be about the same as the thickness of the latching pawl. Internal problems could be the lining has come off the brake disk or the snap ring has come off the front of the output shaft.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
