Re: McCormick Deering 10-20 questions
Posted by nh8260 on August 16, 2010 at 22:07:46 from (96.36.82.222):
In Reply to: Re: McCormick Deering 10-20 questions posted by 36F30 on August 16, 2010 at 20:37:40:
what is the procedure on starting? I don't know it, i'll admit that. so your saying this tractor had the small gas tank at one time, someone must have taken it off at some point? I have a JD A that i still run on kerosene, it has to be above 180 degrees to switch over, how hot does the 10-20 have to be? will it start on kerosene? I only saw a oil pressure gauge on the tractor, no temp gauge. sorry for all the questions, very seldom do i run into something i have no clue about farm equipment wise ;o)
