Posted by Rktman706 on August 17, 2010 at 18:45:11 from (72.161.54.27):
My 706 has developed a high rpm miss I'm still trying to track down, Knowns: Removing air cleaner nearly eliminates it (if not totally) Air cleaner tube from air filter housing to intake is sucking together (normal?) Bled all injectors, each creates a miss. Replaced fuel filters. The last cylinder injector line has a hard "hit" to it. Checked injector pump timing with TDC, lines match up (roosa). Starts fine, idles fine, miss is bad at 1500+ (white smoke). Unknowns: Compression test not done yet.
I plan to replace air filter, maybe air tube if air filter doesn't help. Perhaps run some injector cleaner through it before I get too deep (head would be next). Any ideas are appreciated. I'm new to diesel engines.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
