Re: 706 w/282 high rpm miss
Posted by rustred on August 17, 2010 at 19:35:05 from (74.198.148.43):
In Reply to: 706 w/282 high rpm miss posted by Rktman706 on August 17, 2010 at 18:45:11:
sounds like a bad injector. it should be the one when you loosen the line that least affects engine performance. this way you can track it down to the exact cyl. can be a valve also, compression check is good idea.and also when you loosen the line to the bad cyl the white smoke will dissappear.
