Posted by bkpigs on August 19, 2010 at 19:57:53 from (75.132.223.199):
First off, thanks everyone for the previous ideas and pointers. This is my first mag. tractor so it is a bit of a steep learning curve compared to the battery ignition.
I still am having no luck. I re-gapped the points to .013, no spark. Put the old points back in, no spark.
My confusion really builds when I started doing some contenuity testing.
I get connection between the grounding bolt on the side of the mag. and the frame of the motor. I disconnected the switch from the grounding wire to eliminate the posibility of a faulty switch during this test. Is this normal? I would think not but if the mag. is producing a direction of flow and the windings in the mag are back feeding then it would be, right?
I also get contenuity between the spring side of the points and the solid side of the points. I even removed the spring side completely from the distributor and left it only hanging by the wire. Still got contenuity; that can't be right, can it?
As I stated before in the previous post I did NOTHING to the mag. itself. I just changed the points and cleaned the rotor drive gears (which I got back into the right time).
I have been having my dad hold the wire that comes from the top of the mag. next to a spark plug while I crank and there is no spark. Even if it was out of time (the rotor and such) I should be getting a spark.
Could it be the million to one chance that when I changed the points something inside the mag decided to call it quits? If it did I should have bought a loto ticket that night.
Thanks for all of your contributions. Hopefully I will be able to get the tractor going by Sat. morning to get it to my old hometown's German festival.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
