Re: Farmall B magneto update
Posted by Bob on August 19, 2010 at 22:18:32 from (69.178.228.68):
In Reply to: Farmall B magneto update posted by bkpigs on August 19, 2010 at 19:57:53:
"I get connection between the grounding bolt on the side of the mag. and the frame of the motor. I disconnected the switch from the grounding wire to eliminate the possibility of a faulty switch during this test. Is this normal?"
YES.
The primary winding of the coil has relatively low resistance and is "across" the points, so the "kill stud" will show continuity to ground even WITH the points "open".
With an Ohmmeter that's ACCURATE at low Ohms, you will read the primary coil resistance values between the "kill terminal" and ground.
UNFORTUNATELY, I can't tell you, offhand, what the coil's primary resistance should be.
