Supper C front wheel problem (pic)
Posted by Larry in GA. on August 23, 2010 at 03:58:18 from (75.117.183.133):
Had a flat while mowing, when I pulled it off I notice that two of the mounting ears are loose
How do you go about fixing this ? Several things come to mind but I don’t know what will work best.
All though this still gets dragged to shows it is a working tractor. And with only this and the 2N The C gets to do all the cultivating all the plowing and half the mowing.
Thanks for all your help I couldn’t keep these two going without this board.
Larry
third party image
third party image
And it never ends you move them out spring right after plow days and then you have to move them in again in the fall, Plowing is only part of the reason to move them I need them in to load on the trailer too.
third party image third party image
