Re: Supper C front wheel problem (pic)
Posted by gene bender on August 23, 2010 at 10:37:30 from (67.55.227.196):
In Reply to: Supper C front wheel problem (pic) posted by Larry in GA. on August 23, 2010 at 03:58:18:
I take the tires of sand blast then bolt them to the cast hub and weld inside so as not to disturb the original look as you cannot get new ones. By bolting to the cast center the bolts will line up after welding
