Re: 1945 Farmall A generator/cutout
Posted by John T on August 23, 2010 at 12:18:13 from (66.244.97.31):
In Reply to: Re: 1945 Farmall A generator/cutout posted by gene bender on August 23, 2010 at 10:29:52:
I agree but I do NOT know any SN breaks for when (or if) they went from 2 (BAT GEN) terminal to 3 terminal (BAT GEN FLD) Cutout Relays. The real early cut outs used on tractors with no lights but a genny needed the extra 3rd FLD terminal to supply a field ground for genny charging, but much later when they started using lights they came up with the LHBD light switch to which the gennys FLD then wired, so there was no need for FLD on the cutout relay. However, it could still be used n work by just not using FLD on the relay.....
I bet someone can tell us which IHC used a 2 and which used a 3 terminal relay IFFFFFFFFFFFFFFFFFFFFFFF they ever even did that which I cant say for sure either as I have NO IHC specs or data, heck maybe 3 was allllllll they ever had but just ignored it with a LHBD switch????????????????????????????????????
John T
