Posted by IH fan on August 25, 2010 at 11:57:28 from (70.253.111.148):
In Reply to: 240 utility hyd issues posted by AL Farmall Boy on August 25, 2010 at 09:06:03:
If it blows fluid out the vent and it's not overfull when cold and you check it, it must be getting air in the system from somewhere. First thought would be pump shaft seal, but with a new pump and nothing changed, that's out. Next would be sucking air from the reservoir due to the suction line not being below the oil level, or a hole in a line or loose fitting. You would think it will leak out when not running then, but not always. Something in the relief valve block like the other post is also a good possibility.
This post was edited by IH fan at 11:58:44 08/25/10.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
