Posted by Doug Kieta on August 27, 2010 at 10:17:39 from (67.142.130.30):
I have rewired my '51 H in accordance with Bob M's wiring diagram. I have a 6 volt positive ground system with a brand new 6V regulator. The genny is off of an early '50's Chevy. It is a 6V unit and has been checked out by a local genny shop and declared OK. I have a 3-position O-D-B light switch.
Here's my problem. When the tractor is running, I get no indication on the ammeter that the charging circuit is functioning.
I asked a local mechanic to backcheck my work and see if he could get the charging circuit to engage. After verifying that all was wired correctly, he installed a jumper wire from Terminal 3 on the back of the light switch to the GEN terminal on the VR. With the engine running, he then switched the lights on, and then immediately back off, and the ammeter instantly showed current. He said I should leave it wired that way and just run it. That solution does not seem correct, because when I run it the lights stay on even though they are switched off.
Can someone help me resolve this problem so that the charging circuit works without the jumper wire/lights on condition?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
