Re: H Charging Problem
Posted by Bob M on August 27, 2010 at 10:42:00 from (74.67.187.69):
In Reply to: H Charging Problem posted by Doug Kieta on August 27, 2010 at 10:17:39:
Doug - that's an odd one! Suspect the problem is a mismatch between the voltage regulator and the generator.
Wiring the GEN terminal to #3 on the light switch is a kluge. The effect system on regulation is unpredictable as evidenced by constantly burning lights with the engine running.
For the electrics to work right - also to not risk ruining the generator - you MUST use a regulator for the make & model Chevy your generator came from. A regulator for a stock H will not work!
Before you pursue further you need get a matching VR and generator(!)
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
