Posted by AL Farmall Boy on August 29, 2010 at 10:57:06 from (74.240.94.246):
I am wiring up a 1976 140 using a used harness from a 100 tractor. The 100 had the old style 3 position light switch, and I am using the later version 4 position switch because this tractor has the rear flashers.
The old switch had 2 wires hooked up to the same pole on one end of the dim resistor. Is this ok, or do I need to hook up 1 wire on each end?
Also, are these the headlight wires? Do these tractors have a seperate wire unlike the Cubs where they split off into two wires at the front?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
